Stumbled upon a project boat
DeepCMark58A
I was way over thinking the front backrest I was going to make the back rest all one piece, no need the center is supported I will post up the pictures later this morning.
DeepCMark58A
I thought I was going to have to trim down the entire back rest down to fit, nope just two panels.
DeepCMark58A
Well I was out of town and also busy with domestic projects. Last night I routered out the offset on the back rest and sanded the boards to fit and got the first coat of spar. Going to work on the cushion while I wait for coats of spar to dry. Should have some more pictures of the progress by the weekend.
DeepCMark58A
How does that look?
Ned L
Yes,..... WOW!
What an amazing transformation! Just beautiful Mark.
Woodonglass
That's just terrible!!! I tell ya what, send me your address and I'll come haul it off at no Expense just to save you the trouble!!!:D:eek:
Seriously that's some nice Eye Candy!!!!:sad::clap2:
DeepCMark58A
So I was going to screw the bow cover down and mount the windshield brackets I was drilling and tapping the first hole and snapped the 10/24 tap, this was 5 minutes after the hardware store closed.
Ned L
Crap!!!! I hope you were able to get the broken tap out. That can be a real pain.
DeepCMark58A
I walked away for a couple days, mowing grass and have 2 wagons full of hay to get in the barn. Going to have the bow cover back off it get at the tap, little frustrated.
oldrem
I hate breaking taps - especially the small ones. I hope it at least broke with some still exposed. Oil the threads up good and hopefully can back it out.
DeepCMark58A
Finally got the gasket glued on, the motor goes in next week to be redone. Looks like Labor day for the launch.
DeepCMark58A
Well the motor that is going on the boat is in the hands of the guru. The motor will look like new under the cowl.
DeepCMark58A
I will be slightly overpowered with the 40hp on the back. I do have a remedy for the prop torque forgot I had them. A pair of NOS never installed step and trim tabs.
DeepCMark58A
Whoa found out that the old step n trim tabs are highly desired, might be worth more than the hull, they are still going on the boat, kinda adds to the sexy factor of the boat.
