Sun and trailer tires
Allstate48
Is there anything I can put on the trailer tires to keep them from weatering? We're just weekend fishermen, and the tires wear out from weather, before the tread wears. I've thought about covering them, but that's not an option. Thanks Doug
Silvertip
Re: Sun and trailer tires
Why is covering the tires not an option. Tire covers are inexpensive and easy to slip on and off. Keeping a good coat of Armorall or any other tire protectant is about the only other option.
Shizzy
Ensign
I have seen people prop a chunk of plywood against the tires to block the direct sun.
Im also curious as to why covering the tires is not an option.........
cribber
I live in Florida and the sun will destroy everything eventually that is not metal... moisture takes care of that. Most folks who park trailers or RV here usually cover their wheels with those semi-round canvas covers that fit right over the tire.
Allstate48
The boat sets out, in our back yard.We live in town, on a big hill. The wind blows here all the time. How does the covers hook on, and where do you get them. I've seen them on campers, but never been around them. I just think they will blow off, and be at neighbors. Thanks Doug
Jersey John
You can get them where they attach to the fender with either snaps or magnets. You could also get them for your size tire that will slip over the tire under the fender. Any RV shop should be able to point you in the right direction,that is where I got mine for my enclosed trailer that I only use like 3 time's a year.
Shizzy
Ensign
Im sure that could be alleviated with a little rope....
lakelover
I just bungee old garbage can covers over them for protection from the sun. The plastic ones don't even look too shabby.
cribber
There ya go... several options out there for you and I really liked Lakelover's response... very creative and I like that idea. ;)
gostephen
i had the same problam ilive in arizona whare between the 300+ days of sun a year the 100+ degree days with less than 10% humidity anything rubber drys out very fast
i used to replace my trailer tires every other year then i found 303 aerospace protectaint now im on my 4th year and they look brand new
1 good coating seems to last about 5-6 months
its avable at some autoparts stores and online at overtons and most marine supply sites
eli_lilly
2nd on the 303 Aerospace... I use it on everything rubber and plastic on my boats and cars from day one. On the boat, I also use it on the aluminum windshield frame.
-E
