Super Slick Substitute for bottom paint
clop321
Has anyone out there used super slick to substitute for bottom painting ? Wondering how effective it is or how easy of clean-up. Going to drop my boat into salt water for 1 season (hate to paint it). Thanks.
Spidybot
Re: Super Slick Substitute for bottom paint
Did a BIG job removing many years of old build-up of paint. Applied primer and VC-17 Teflon antifouling. Works great, never builds up and makes the next year application as easy as that.
outonbizniz
try reading this post...the stuff you're talking about is SeaSlide.<br /><br /> Earlier post
clop321
The product I was talking about is 'super slick' wax. It is sold by overton's and could be applied directly to gel-coated paint. It is suppose to be eliminate bottom painting so you can preserve the finish.
outonbizniz
Sorry, I read your post as a question of what the super slick stuff was...Never heard of the wax...i'll check it out.
fishthebay
Hello:<br /><br />I used a product from West Marine last year that I believe is called easy-on. Same thing and what you were referring to v.s bottom paint.<br /><br />Anyway, I keep my boat moorned in the Chesapeake Bay. I live in Virginia Beach. <High salt water content><br /><br />Now, regardless - I take my boat out about every 3 weeks to powerwash the bottom. The bottom wax actually helped a lot.<br /><br />I wouldn't say it eliminated ALL the growth, but growth was more slime than barnicles. <br /><br />The slime can be washed away with boat soap and water, so yes the stuff works - but with some degree.<br /><br />It is really rated for low fouling areas, which saltwater isn't. It would work great for brackish water, but as long as you take your boat out of the water lets say montly to wash you should be OK><br /><br />Hope this helps.<br /><br />PS - You just wipe the wax on with a sock or something. You DO NOT buff it off. It dries like a silicone substance.<br /><br />You can even do your upper hull for more easy washing and to add a bit of a shine.
clop321
thanks for the help ! I'm also in high salt area (north Jersey) but will definitely try it... I'm assuming it removes easily also ?
