Surface prep when using Gluvit
tinkerr
Hi Folks,
I have stripped the rotted floor from my aluminum 16" Bass Tracker and as a precaution while the hull is exposed I want to use Gluvit on the rivets. I'm using a strong detergent and pressure washer to clean the hull. Is it necessary to use a aluminum wash and sand the hull? How long would it take to sand the rivets(not getting any younger)?
Thanks
Woodonglass
Re: Surface prep when using Gluvit
Sanding would be ideal but at the very least wipe down with Acetone to remove all traces of oil or grease.
