suzi dt50 bottom end off help!!!!
vin rouge
ok, so ive bought my first boat, with a crusty dt50 motor roughly bolted to the back. ive lovingly rebuilt the entire grp shetland boat, after some eejit butchered it by cutting the cabin off to try and make it look like a speedy speed boat thing, and now im about to attack the engine.
ive unbolted the 8 bolts holding the gear case on, have dropped the case @40mm, can see the waterpump housing with drive shaft going into it, and the shift rod. now im scared.
there is no water tube as in brownspoint microfishe, and how do i disconnect the shift rod??
please dont tell me to buy a manual or go to a suzi dealer, cos im british and live in the uk, and all us brits are broke cos of our prime minister. ta lots for detailed help pleeeeease!!!!!
deejaycee_2000
Re: suzi dt50 bottom end off help!!!!
You can disconnect the shift rod, put the lower unit back into place put the motor i gear and you will see the shift rod in the gap at the back of the motor, where you can disconnect it ....
vin rouge
thanks dude. got the bottom end off, impeller had only two blades left and the water tube has gone hard and snapped. fixed it with new parts from marine bazzar in plymouth, devon uk. getting the whole motor sand blasted this week and then re painting it . should get it back into the water this year! maybe.....!
vin rouge
oh yeah, i blasted compressed air through the system and blew out bits of old impeller. nearly shot the cat, but hey-ho!!
