andrew j cox
Thread starter- Joined
- Feb 11, 2015
- 149
So the anti christ has dropped spark on 1 and 3, no spark on tester, wiring to coils tested well within range, so replaced Flywheel, stator, trigger, CD box, rectifier, is switch with parts of spares motor, this solved the sneezing but no spark on 2 cyls,
likely causes? Trigger could be stuffed, Stator?
Has 3 new coils.
compression even all cyls 140 psi.
can I test the trigger with a multi meter?
can I test the cd unit, I figured if 1 fires the other two should, why would I then get correct ohms to the coils, but no spark from the coils, this engine is driving me to drink, what else can I do?
Has 3 new coils.
