Re: Suzuki outboards.....
JB<br />Regarding the pump drive, the cam has been improved in 2002. There is no bulletin, but the replacement cam will fit back to 98. The sharp edges machined in the slot have been rounded off and the metal has been hardened... <br /><br />What200<br />Can't bypass rev limiter. If you are always limiting, try a more radical prop...<br /><br />Danmck<br />Suzuki thermostats will distort to the "open" position in the event of an overheat...<br /><br />philtheskipper<br />Check the water sensor for accumulated debris, or wear in the pivot. If careful, you can clean it...<br /><br />After observing the mentality of the Suzuki rep, I would certainly buy a Suzuki product. It seems customer support is number one....
