QC
- Joined
- Mar 22, 2005
- 22,783
Re: Swapping out a 305 for a 383.
Some clarifications may help this thread . . .
This is kind of correct. The most total power is actually at peak horsepower, so for extended wear and tear, WOT (peak power) has the most power going in (and out), so the most total heat, wear etc.I honestly have never understood this advice. Look at the torque curve of any marine engine and you'll see that it's lowest torque (force on the drive) is at the bottom of the RPM range and maximum torque is reached around 3500- 4000 RPM depending on cam grind.
But maybe not the hardest. Yes that initial twisting point (torque) may break something, but WOT is a big deal too.Bubba, static friction takes more force to overcome than kinetic friction. And for every force there is an equal and opposite force in the opposite direction. If you understand those two concepts, then you'll realize why hammering the throttle from a standstill is so hard on an outdrive.
Agree.It also isn't anywhere near 400hp, more like 325, with Merc advertising the newer ones at 350. But not with stock exhaust manifolds.
300 bhp Mag MPIs are sold with Alpha's even today. Propshaft horsepower. Stay tuned . . .Hmm..looking at my manual, it doesn't look like Merc used an Alpha I (even Gen II) past a 260hp 5.7.
If you check closely the factory Merc 350 bhp ratings are at the flywheel, and 325 at the propshaft. Even Alphas eat about 8% or so going through the drive. Say 30 horsepower. The "Merc 260" of old is actually only a 230ish when rated as they are now. No way with a reasonable marine cam are you going to see 400. Either at the propshaft or the flywheel. Go radical street cam and wind her up then maybe. Look for no more than 350 at the flywheel and 325 at the propshaft for reasonable expectations. Take it easy with the right hand and you should be OK with the Alpha.The 383 I'm looking at is available up to 400hp.
