sync / link questions not in book...
imstillatwork
for 1981 70hp evinrude<br />I have been going over the procedure from the solec manual and have a few questions...<br /><br />It seems to assume that the throotle linkage from the cables is adjusted properly or seems to be leaving out a detail. When I loosen the cam roller on the carb, it does not even come close to being able to line up with the short mark on the cam plate.<br /><br />How do I set a baseline setting for all the linkages before I start the sync procedure? The book just doesn't seem to cover it. Or I am missing something...
DHPMARINE
Re: sync / link questions not in book...
I am not a fan of Seloc,And I don't have the Evinrude manual here.<br /><br />I think the baseline starts with the throttle cable not attachted.<br /><br />Then setting the idle screw to a few degrees of timing,then doing the linkage.<br /><br />Guess we both need the real OMC manual to do this.<br /><br />DHP
Todd Humphreys
I hope that I can describe this in understandable terminology. My 1982 75hp has a arm that is attached to the cam plate that is threaded. You can adjust the cam closer to the linkage by turning it counterclockwise (unscrewing). I believe this applies to your motor. Can someone else confirm this.
imstillatwork
Ahhhh. it does. There is the cable that attaches to the main big lever, then a smaller metal rod that attaches to the cam plate. It is adjustable.<br /><br />Adjusting that rod would indeed get the cam plate closer to the cam roller, but that would not answer the question of is my ignition timing correct? <br /><br />
<br /><br />refereing to image above ( http://www.lot-o-nothin.com/lotonothin/viewimage.cfm?id=101 in case you can't see it.)<br />A: cable adjustment<br />B: Rod from throttle lever to cam plate.<br />C: Timing advance lever.<br />D: Threaded adjustable section of rod to cam plate.<br />E: Cam roller / follower on carb throttle linkage.<br />F: Linkage to timing advanced (no adjustment)<br />G: Idle speed adjust. brings throttle and timing up.<br />H: WOT stop adjustment (edited)<br /><br />After I find TDC, do I adjust D (with timing light of course) to set the initial idle timing to the spec? making sure that it is not pushing the throttles open at idle.. riiight?<br /><br />Then, if E is out of range, do I need to adjust D to bring them together? <br /><br />If the idle timing is 100% correct, and the roller and cam line up perfect, then the WOT timing MUST be correct, correct??<br /><br />The cam plate is shaped like it is to change the timing / rpm curve, rather than a linear timing change through the rpm range I assume. Thats why the short mark is so important.<br /><br />Then the little adjustment wheels at the cable (A) are for slack adjustment?
imstillatwork
now I am feeling dumber and dumber...<br /><br />I read the manual like 5 times, and after I posted, and looked at the pictures and all that, I see the part I was missing..<br /><br />"If an adjustment is required, lengthen the throttle control rod to increase timing degrees or shorten the rod to decrease the timing degrees."<br /><br />Timing control rod is D on my pic.<br /><br />feeling dumb about now. This is somthing I should have no problem with at all!
Silvertip
Don't start in the middle of the sync & link procedure or it will still be wrong. Start at the begining and follow every step.
