EHardgrave
- Joined
- Mar 25, 2005
- 56
We have converted from a 91 2 stroke to a 02 4 stroke using a wiring harness adapter. We purchased a new system check guage and have that working. Off of its harness is a 2 pin connector we purchased a Radio Shack 12v buzzer. (I know should use OEM) when the key is turned on we get a 1/2 second beep like you should. We then unhook the temp sensor wich starts the check engine light blinking a code. When we short the tan/stripe wire to a ground the overheat light goes solid but no alarm sounds. I know it's not a OEM buzzer but due to the test sound I don't think that is the problem. Any ideas?
