not enuf toys
Thread starter- Joined
- Feb 14, 2011
- 428
96 5.7lx 4 bbl mercruiser 21 pitch 3 blade SS
so WOT was getting to about 5200 (if i would let it). this had happened everytime i took it out this year. engine sounded high, speeds were 57 - 58 (verified on 2 different gps). everything sounded about right
had an issue 2 weeks ago with killing the battery while sitting too long having too much fun...if thats possible
come to find out when i got home that the battery may not have been that dead rather the el cheapo battery quick disconnects were garbage and were not making good contact with the main battery posts. all of the other electrical that were running off the secondary posts were running fine (even though amps were low)
so i cleaned up the main posts and replaced the terminal connectors on the main battery wires
now where the strange tach issue occours...
the rpms are 4200 to 4400 and the speed is still the same (still verified).
so my options are ~ pull out the tach and have it tested or check the rpms of the engine and verify to the tach.
where would you start?
motor sounds to be running the same rpms (i can hear the difference inbetween 1000 rpms, or atleast i think i can)
what do you think happened here?
i haven dug into it at all yet as i just noticed this monday. what does this tach get its pickup from? is it old enough to pick up from the alternator?
