Tach reads wrong at start-up
Wylie CC
I have a 2000 Chris-Craft with a Volvo 5.0 GI and SX-M drive. When i start the engine, the tach will read over 2,000 RPM, but when I tap the tach, it will jump up to around 3500, then tap again, and it goes to where the engine is idling. Then it is fine until i shutdown, then it occasionally does it again after a warm start.
Could this be a bad electrical connection? I have verified that the tach is set to 8cyl on the backside.
I am a newbie so wasn't sure if this goes in this forum or not.
Don S
Re: Tach reads wrong at start-up
Probably corrosion inside the tack itself, and will probably get worse. Might try turning the set screw where you set the tach to 8 cyl., back and forth a few times and see if it helps. New tach is the only sure cure.
Ayuh,... It's on it's way Out...
The twist the switch trick works for awhile, as the thumpin' with yer fingers...
Eventually, you'll be buying another 1....
wakina
Had the same problem three years ago, acted the same way. Replaced the tach and have not had a problem like that since replacement.
PuddleJumper
When I used to be on the Regal forum it was lovingly referred to as the Faria Tap ;-)
madurodave
May i ask what setting is the 8 cyl? Which contact, 1st, 2nd, or 3rd? Just curious.
Wylie CC
Thanks so much for the info. I guess I will try to hold out until it goes, then look into rebuilding it to try and keep the guages all the same.
"Faria Tap" I like that.
You guys are great
