Tachometer
fmjnax
I've got a 1985 Mariner 70HP that I want to get a Tachometer for. Is there anything special I need to look for when shopping around for the tach? My Mercury Quicksilver control box has a pass-thru plug on it for the tachometer, but I want to try and wire it directly to my harness (I'm doing a restore on the boat, so I have a brand new harness and easy access to it).
fmjnax
Re: Tachometer
When searching, I found some sites that listed them with something about poles 4, 8, or 12?). Do I need to be mindful of this?
fmjnax
Re: Tachometer
*bump*
I can't figure this out. Is there a certain # of poles I need for a 3-cyl motor?
fmjnax
Re: Tachometer
Still haven't been able to find any information regarding the poles. Does it even matter?
mr roach
Re: Tachometer
i just got done putting a tach on my 77 115 merc i6 and poles do mattermine has twelve pulses so i had to set my tach for 6 pulses as you set it for half of what the pulses are i used a faria tach as it had the most settings it had settins for 4,6 and 8 cyliner engine as well as different pulse settings to fit a wide variety of applications. just my two cents worth. also farias website has a decnt explanation and illistration for their tachs
fmjnax
Re: Tachometer
Awesome. Thanks mr roach. I'll get on their site and see what I can find.
Barnacle_Bill
Re: Tachometer
Your stator has 12 poles so you need a tach that can be set to 6P (pulses) which is the most common.
