td-20 What year and were to get points
865Johnson
Greetings
I dug out an old Johnson TD-20 out of my parents crawlspace under there house which had been there for approx 25 years. Was given to my dad by my uncle, Both of which have passed away. Thought i'd get the old thing running again. Cleaned carb and points, replaced footgrease with gearlube oil. Got the thing running but one set of points keeps arching out and when it does i get intermitting fire on that cyl. I swapped points around to make sure it wasn't the coil or condenser and sure enough the other cyl started firing erratic. This set of points have been ground down way too much by a previous mechanic. The contacts on the base are almost gone. The contacts on the copper arm still look ok. I had concidered welding/soldering on the old base contacts and trying to fab them enought to work but would rather buy a set if they are available anywhere. Also from internet search i know that they were built from 46 thru 49. but i can't seem to find a serial # chart to find out what year for sure it was built. My Serial # is 670034. Any help would on either subject would be greatly appreciated. Would kind of like to get it going and use it again. Kind of a sentimental thing i quess.
Thanks in advance
JB
Re: td-20 What year and were to get points
All TD-20s are about the same, 865. Points for one will work just fine in another.
You can probably find points and condensers at your local NAPA Auto Parts store.
If you haven't changed the impeller you need to do that quickly.
Great little engine.
865Johnson
I forgot to mention the impellor. I checked it also. Still seems good. Isn't hard or brittle. The motor pumps water good. So i think i'm ok with it for now but if i can get a new one i'll change it just to be safe. I'll try Napa today and see what gives. I'm just curious as to what year it is. I know there must be a serial # chart that breaks it down to exact year rather than just a generalization that you get from the model # I just haven't been able to find such chart on the internet.
Update. Just Called Napa. They only have a listing for a 1965 thru 68 johnson 5hp. Anywhere else that might have them?
865Johnson
Thanks FR. I'll give sea-way a try. Thanks for letting me know which year it was. Do you have a shop-manual that has a chart as to what serial #'s where made in which year. I'm curious as to where the info is and if there is a site to find that info or do you have to have the service manual. I Did some research on this forum and others and i've seen that others have been able to give out there serial # and people have told them which year it was but wasn't sure where they were getting there info. If you know of no website then maybe it would help others if could post a chart on this thread.
Thanks
865
14FTBOAT
I just got a johnson sea horse 5 1/2 ser.#512531 mod. td 20 . Can some one tell me the year. And the web site listed ,Can i get parts for motor no spark. Would this motor push my 1964 seaway aluminum boat fine?
F_R
512531 is a 1946. Reference is "The Old Outboard Book" By Peter Hunn. His list only goes up to 1961. You might want to get a copy of the book, good reading for the old motor collector.
ISBN 0-07-031281-8 Published by McGraw-Hill
steelespike
A good running TD20 will plane most small boats.You may need a tiller extension so you can sit in the middle seat.Also careful weight management and placement.
865Johnson
FR Thanks again for the info. I was wondering where the serial # info was coming from. I think i may have found a new hobbie (old boat motors) so i may look into purchasing that book. Got a reply back from sea-way and they do have the points so i'm going to get them ordered tomorrow.
Thanks for all your help
865
