As I'm ripping out the deck in my Glastron V-147 I'm thinking of just how I want to replace it. My preference is for a removable deck. Here is my thought -
The original deck was fiberglass over 1/2" plywood. The plywood only went out to about 1" from the hull, the very edge where the deck attacked was only fiberglass ~1/8" thick. Deck was supported on stringers (light blue in drawing), and two cross supports (purple).
My thoughts for removable deck:
Cut out all plywood leaving 1" flange of fiberglass where old floor attaches to hull.
Extend two cross supports and screw/glass them to fiberglass flange at each end.
Create ledge to attach decking -
"Peanut butter" hull side of resin soaked/glassed 1"x2" and screw in place. Once "peanut butter" is hardened, remove screws and drill screw holes out oversize, fill with resin, re-drill to screw size. Glass over 1"x2" and flange.
1/2" plywood decking will be screwed down to 1"x2" with finishing washers at outside edge. 1/2" plywood decking will be screwed down to stringers/cross supports everywhere else. All holes will be drilled oversize, filled with resin, and re-drilled to screw size.
So... will it work? Dumbest idea ever? Good way to do a removable deck? Provide enough stiffness when screwed?
Aaron
Aaron
