edfishing2
Thread starter- Joined
- Mar 6, 2011
- 144
The vacuum switch has one lead that goes to ground. The other lead goes to an insulated lug on the bracket. The wiring has twin tan (labeled V) wires with a ring terminal that goes to this insulated lug. The wiring diagram shows one tan wire on the boat side wiring harness and 3 tan wires on motor side wiring harness. One tan wire is very clear it hooks to one of the thermal sensors in the head on the starboard side (not shown in photo). The diagram shows a low oil sensor but I do not know of a low oil sensor in my outboard. If you look at the photo it looks like one of the thermal sensors was not even hooked up (marked with a T). The diagram shows the port thermal sensor in-series with this vacuum switch.
Here is the question. Where does this in-series happen as it looks like there are two of the blade type connectors. Has someone (previous mechanic/owner) hooked up the low oil sensor to one leg of the vacuum incorrectly or the thermal switch wire ? Pin out of motor side red connector may help me out.
Evinrude E100WTLCRS
Evinrude E100WTLCRS
