Tempo Products 6.5 gallon gas tank
LSU
Someone gave me a used Tempo Products plastic gas tank.
Other than some grit and exterior dirt, it looks fine. A bit faded from sunlight.
I'm going to clean it up and pressure/leak test it.
Comments?
Suggestions?
Thanks.
GA_Boater
The plastic tanks do fade from the sun, but usually just look bad.
Is this one with the vent screw in the filler cap? Just put a little gas in it and close the vent, then let it sit in the sun for a short time. If it starts to balloon and you you don't see any gas leaking as you slosh it around, I'd say you have a good tank. Then loosen the vent to relieve the pressure.
LSU
It has a cap with a vent. I like your idea and will try it.
How does this type of tank pick up the gas?
Is there a vent screen or something else I should clean?
Thanks.
