Testing control box horn?
mark1961
Ensign
Hello,
Is this just a matter of grounding out the wire at the motor temp sensor?
Cheers.
tashasdaddy
Re: Testing control box horn?
disconnect the sizzor connector and with key on ground to block.
ezeke
Disconnect the temp switch at the engine and ground the control end of the wire to the engine block with the ignion switch on.
daselbee
Not so fast fellas....
What year motor? On 1996 and up Systems Check engines, the horn will NOT sound when any of the tan sensor wires are grounded, UNLESS the engine is running.
The lights on the tach will light up for the fault that you are testing, but the horn will not sound unless it is running.
Older than 1996, the advice is correct.
mark1961
Ensign
Sorry, i should have been more specific, its a 1982 60hp rude E60TLCNM, i would just like to know if my control box horn is functional.
Thank you gents for the info.
Cheers.
ezeke
Cheers.
I looked at your previous posts before I entered my earlier advice, which is still the same.
