The 2010 FrankenMerc Project
sschefer
Re: The 2010 FrankenMerc Project
Don't worry, i don't criticize you, you're lightyears ahead of me when it come OB rebuild. I've only done a few midrange (40 to 90hp) and nothing near the sport cut you give them. I learn a lot from your detailed posts.
Saumon, it wasn't meant that way:). I was just trying to say that there are a lot of different way's to skin a cat so if you find a better way.. By all means go for it.
Do be carefull with the Vasoline though. I tested it and it doesn't mix well at all. 2-4-C disolves in 50:1 mixed fuel enough to satisfy me. Pure blended 2 stroke oil is probably all you really need on the big ends if you're using high performance steel caged bearings like me. I'd probably use assembly lube if I was running plastic cages.
The reason I don't use much of any assembly lube at all is because it's not needed like you'd need in a 4 stroke motor. The amount of 2-4-C that I use is just enough to feel that it's there, there's no build up or excess.
saumon
I don't use Vasoline anymore. I only put a thin film of assembly lube then dip them in Quicksilver Premium Plus 2-stroke oil. Oh, and ditch the plugs after the break-in ;)
sschefer
There ya go...
sschefer
Pre assembly - Any good engine builder will tell you, the worst thing to find is an ill fitting part or one that's out of spec during assembly. Cleaning up sealants and replacing gaskets a second time is not something that you want to do. Pre-assembly also gives you a second chance to make sure that you have everything you need for final assembly. Things like nut's bolts and washers missing will distract you from what you're doing.
Here's Frank, pre-assembled with the only gaskets in place being the head gaskets. On those, I squish my first set.. They become sacraficial and I don't use them again. I measure the gaskets after they've been squished then I use that figure when I calcualte my squish band.
I also wait until now to chase threads on the bolts that I'm not replacing. It gives me a chance to take a second look at them to make sure I didn't miss any chipped or rounded threads. It's not all that important with cast iron but with aluminum it is imperative that the threads are sharp and clean or you will strip them when it comes time to torque.
Here a few shots -
and another
Notice the degree wheel? I like to check each cylinder and record the length of stroke, TDC, 45 degrees (.462 on this motor) and at 25 degrees (.150). You could do this with some extensive math but the degree wheel is so much easier.
As a side note, a lot of folks take .462 and divide it by 45 and try to figure degrees of advance in inches of stroke. It doesn't work because you have both a reciprocating mass and a rotating mass. Just use the 35.00 degree wheel and you'll be accurate enough.
Dukedog
Looks good. You've come along way compared to your first deal with tha v6. Congrats!
BTW, Ya probably make "REX" happy with your little 2 liter ................
sschefer
Thanks DD.. I think he's probably laughing saying, "beand er doned at".
sschefer
Checking the timing.. With everything tight enough now to get some good measurements, I'll check the timing.
I'm using a Jay Smith Dial Gauge that is custom designed just for these engines. It has a 2" stroke and has been adapted with a spark plug hole fitting so it screws right into the head. PM me if you want more info.
I start with #1 and get a 0 reference. You can't use zero to verify timing but you can use it as a reference as long as you understand that 0 is TDC and the point at which the piston stops for very brief moment before it starts back down. When you use a degree wheel you can rock the crankshaft back and forth until you find the number of degrees in the dead zone and then split this in half. That still won't be dead on perfect but it will be close enough.
The degree wheel and pointer set to zero -
The gauge set to zero -
Now we rotate the engine clockwise and stop at .462 back from TDC. I prefer to make a full clockwise rotation rather than backing off counterclockwise past .462 and comming clockwise back on it.
Here's the gauge at .462 -
and here's the degree wheel at 45 degrees-
And who said checking dwell was a thing of the past..... HA..
Continued in next post........
sschefer
Continued from previous timing post....
O.K. so now that we have our baseline, we can continue and check all the other cylinders. You do not want to move the degree wheel. You just reference TDC then find .462 back from that.
And here is exactly why you need to do this.... This is # 3 and it's 1 degree more advanced than # 1 or 2. # 4 was the same and it stands to reason since that is on the same lobe of the crank shaft.
This problem can be corrected but would be very expensive to have done. Almost every Merc crank will have this problem and it is not a bent crank because we checked for that a long time ago. This is something that happened when the crank was origninally ground. I've seen a couple that were out as much as 3 degrees and those I would not use but this one is O.K.
Because I did not make any changes to the engine that would effect MAX WOT timing we must use the baseline of 25 degrees as a well known number. This engine would be at risk of detonation on 3 and 4 if I set my MAX to 25 so I will set it to 24 instead. That will leave me with 4 that fire at 24 and two at 25.
The nice thing about all this extra work is that I know. If #3 or #4 were to melt down and I had not done this check I would be scratching my head for sure.
If it was off more than 1 but less than 3 I would also increase the jet sizes on 3 and 4.
See how much info this little check gives you.... Try not to skip it.
sschefer
Rod bolts arrived today..
I first disassembled the engine from dry fitting and then replaced each rod bolt. It is very important that you check each cap to make sure that the are properly fit. I can't stress this enough, it is so easy to get one slightly off.
I use Loctite 271 gel on all the rod bolts and then install them. These get torqued to 15 lbs, then 20lbs and finally a full 90 degree turn from the 20lb point. I like to go through all the bolts at 15, then all at 20 then give them the final 90 degrees.
Once all the bolts are torqued, I set the sealing rings so the openings are center at the top like this -
The next step is to wipe down the sealing flanges of the block and the front half cover with Acetone. You can also use loctite primer but Acetone does the same thing.
Once both side are as clean as possible, lay the cork gaskets into the front half and put a bead of LocTite 518 directly on top of the cork. I also put a thin line of it at the front and rear bearing cap joints.
I then install the front half and tap it down with a wooden mallet. This sets it in place without messing up the cork gaskets. That's what works for me, you may have a different way.
I use my impact driver, set at 20lbs and tighten the bolts according to the torque sequence in the manual. I finish them by torquing them to 38lbs.
Next, I tighten the endcaps into place. The reason I wait until after torquing the front half is so the O rings on the caps don't get pinched. If they do, there's a chance they could leak.
Finally, I set the assembled intake in place and torque it down. These get 12.5 lbs of torque which doesn't sound like much but you have to remember they're only 1/4" bolts.
Here's were we are now --
After I dry fitted the heads and checked the squish band I put new head gaskets on it and torqued the heads. On heads, I like to to 10, 20, 30 then let it rest for a while and retorque to 30 and give it another 90 degrees after that. I use LocTite blue on the head bolts just for a little insurance.
The manual calls for using oil on the bolts in several areas. I do not do this, I don't like it, I've stripped too many threads doing that. I either use LocTite red or blue depending upon the probability of removal. Do whatever you like, this is just my preference and it seems to be working.
Heres the heads and divider plate installed and torqued -
So heres Frank --
Tomorrow night, I'll get the hoist out and mount the powerhead on the mid section. It's easier to work on that way.
sschefer
O.K. It's tomorrow night. The hoist is out and Franks comming off the engine stand. I just want to say one thing before I get started. If you do a project like this go to Kragen/Oriely or any other chain autoparts store and spend the 300.00 on a 5 ton engine hoist and engine stand. It will save you many headaches rigging chain hoists and trying to figure out how to do the lifting without damaging something..
Here we are taking the engine off the stand. It's easy just put the flywheel on the motor and give the nut a cinch then screw that ever faithful lifting ring into the flywheel. Hook your hoist hook onto the ring and start lifting. If your pin is in your engine stand, pull it so the stand can fall away as you start lifting --
When the stand falls away the mount plate is all that's left on the engine.. Simple...
Now remove the plate and install your studs in the block. I use Loctite red on the threads and screw them in by hand and then a little bit of tightening with a pair of vise grips.
Here's the studs --
I coat the gasket on one side and the the exhaust plate on the other. I install the gasket to the engine side, over the studs and the sealant holds it in place.
When the gasket is in place on the block its time to drop the powerhead. I have the lower unit on this mid so I wrapped a rag around the prop shaft a put a pair of vise grips on it then put it in gear so I could turn the prop shaft to align it.
All you have to do now is wheel the engine over to the mid, line up the bolts and drop it on.
If you're wondering, the battery is for the trim/tilt. It's handy to be able to adjust the mid when you're dropping the motor on.
Notice that I did not put any grease on the studs.. Hard lesson to learn here. If you do, it squeeze between the gaskets and they leak. Do it if you want, Merc doesn't and neither do I anymore. I will coat the threads and pack some up around the stud when I put the nuts on.
Another thing about using permatex 2B is that you don't have to tighten anything down or even put the nuts on yet. You can let it take a natural set and then tighten it down. Seems to work better when I do it that way.
Next up..... The plumbing and electrical work... Those of who have had problems in these areas are about to get a treat... I'll be showing you exactly how they work as I install them.. A lot of mysteries are going to be unravelled and a lot of myths are going to be put to rest. The fun is about to start...
sschefer
Started the weekend a little early so went and got the stainless hardware I needed and a few other necessites.
The first thing I did was fill the lower unit with lube so I wouldn't forget to do it later. I fill it until it runs clear and then let it settle for an hour or so. Then I top it off. I put the upper plug in then remove my pump from the lower and let a couple of ounce of fluid run out then put my plug in. That leaves a little room for expansion and keep it from blowing seals.
Next I started mounting carbs and running tubing. I alway start with the bottom carb when installing. Just a little trick I learned.
I'm running a 2.5 intake so I'm using the WMV style gaskets. I cross drilled the choke wells in the carbs so they dump into the venturies instead of dumping into the intake channels that don't exist on these intakes.
You'll want to run as much of the choke tubing as you can as you install the carbs. You can do it later but it's eaiser to route it now.
Here's all the carbs mounted -
I then installed the trigger and the stator. The trigger has 3 coils in it and the magnets for the trigger are in the center hub of the flywheel. The trigger is completely independent of the stator. The center hub of the flywheel actually has two sets of magnets. These are layered top to bottom and are reversed. In the first 180 degrees of rotation the three coils generate around 2 volts and then because of the second set of magnets, the coils produce voltage again in the second 180 degrees. This is how they get away with only using 3 trigger coils.
Trigger coil # 1 fires #1 switchbox SCR during the first 180 degrees and then fires # 4 switchbox SCR on the second 180. Coil #2 fires 2 and 5 and Coil # 3 fires 3 and 6. Rember we're talking about trigger coils not spark plug coils.
As you can see if you don't have fire on 1,2,3 it's pretty hard to blame the trigger. but if you had no fire on 2 and 5 then trigger coil #2 would probably be the culprit. O.K. that's how the trigger works so now let's mount it up.
I polish the surface where the trigger sits and I put a light coat of 2-4-C on the surface for lubrication. I then set the trigger in and check for binding.
Now let's take a look at that stator and dispell a few myths. This is a CDI stator which has exposed coils. This is also a 16 amp stator. I have a 40 also but I'm breaking the motor in with the lighter 16amp flywheel so I use the 16 amp.
This post was edited on 07/4/2010 ==
Here's a close up of the coil.. The charging coils and the spark coils have one thing in common... Negative. There is no ground in these circuits but it is common to refer to negative as ground just as we refer to it as ground when it's real name is earth, just ask someone from the UK.
You'll never have a connection to earth in a boat unless you are clearly stuck in the mud.
The negative side is provided by the battery or the stator/alternator if the battery is not present. Because the stator is an alternator the act of passing a flywheel magnet over a stator coil will produce both negative and positive voltages. It is for this reason that you are always cautioned to remove the plug wires to prevent accidental starting when working on the engine.
If a charging coil or a spark coil should short to negative or if a rectifer/regulator was shorted to negative (or for that matter anything with a positive voltage) it would probably at the very least, cause erratic spark. The most common and least obvious visually would be the rectifier/regulator which is why one of the procedures in trouble shooting is to disconnect the two yellow wires (stator charging circuit) from the rectifier/regulator.
The pulses for your tach are determined by the number of magnets in the flywheel. If you have 6 magnets you will have 6 pulses because a magnet would pass over a coil 6 times every revolution of the engine. In reality, you would have 12 pulses as the voltage alternates between positive and negative. Approximately 1/4 of the way through the pass the voltage will be at peak positive (lets just say it's +12v) and at 3/4 of the pass it will be at peak negative ( lets just say it's then -12v). This point at which the phase shift occurs is not exactly at 1/2 but this info is accurate enough for this example and for what you need to know to make your engine run correctly.
Stator position is first determined by where the wires come down the block. This is the normal position--
Now align the screws in the screw hole adjusting positon as necessary. If you experience a weak spark condition, then go back and move the stator one screw hole in either direction to correct it. You'll do this as part of the pre start link and synch procedure.
The reason this occurs is becuase of the way the magnets pass over the coils and the fact that the trigger is independent of the stator.
If a stator magnet is passing over a coil too late or too early and the trigger magnets (center of the hub) pass over their coil on time then the trigger voltage will flip the electronic switch (SCR) in the switchbox. This will release the voltage in the switch box capacitor to the coils before it has reached it's full potential voltage. If the voltage is high enough it may still produced enough voltage to jump the gap at the plug but the spark will be weak and could be intermittent. In a worst case scenario, there will be no spark at all.
As a side note, a misaligned stator could still start and run an engine with fairly good results if other compensations were made, (and they usually are). As time goes on the problem will likely begin to show up as a rough idle and poor performance (lower than normal max RPM).
The above is the reason we stress the use of a DVA when reading voltages from the stator. The test for a misaligned stator is first the spark tester, then the voltage at the positive side of the coil. Finally we need to test the stator to see if it is producing the correct voltage. If the stator is misalinged or out of synch with the trigger it should still produce the voltages it is supposed to. If the stator is producing the correct voltage, turn it 1 screw hole in either direction and retest at the coil. If the voltage is niow lower or non existent at the coil then the problem is not the stator it is the switch box. Put the stator back to the original position, replace the switch box and test again. If the voltage at the coil is now correct, then button it up and go boating.
sschefer
This one is for J_Martin.. This happened to him, it happened to me and if you don't pay attention to this it will probably happen to you... All I had was a couple of sets of stator screws for 40 amp stators and I'd already been to Home Depot so I used them.. If you do that this screw right here will stop your trigger advance dead in it's tracks and you're max advance will be about 17 degrees.
I just ground 1/4" off it and then put it in... This is how it should look --
Next I put the bleed tubes on and the lube tubes for the center mains. Don't skimp on these hoses. There's plenty of room to run full 1/8" tubing.
Here's the port side routing --
Here's the stbd side --
Now the electrical plate can be installed.. Be sure that the the bleed tubes do not get pinched behind the plate. It takes a little futzing around to get them in the correct spot..
Continued in next post --
sschefer
Next I mounted the CDI rectifier/regulator --
Here's the leads off the rectifer/regulator...
The two yellow are comming A/C voltage and are comming from the Stator. There are two red wires. One is fatter than the other. The fat one is regulated output. The skinny one is the voltage sensing circuit. It gets input from both the battery and the fat red and from that regulates the voltage that is on the fat one.. For instance, if the engine is turning 6000 RPM and putting out 18v on the fat red wire, the skinny red wire senses that and regulates the fat red output back to a safe 13-15 volts.
That's enough for today..
Faztbullet
Here's a close up of the coil.. Count the coils and then notice the yellow charging circuit wiring. See how the spark coils are also in the charging circuit.. Suprise... yes, it is true that a grounded recifiter/regulator or a bad tach can cause spark issues.
Not completely accurate, yes a sorted rectifier or broken stator leads can cause a ignition problems but its not because of it being tied into ignition coils. The charging circuit wires wrap around the high/low speed coils so they exit in the same place, and are not attached to them in any way. You can actually take both yellow wires and ground them to block and engine will start and run untill stator overheats. For more information contact my buddy T.J at TJcdielectronics.com or Sean Hill @ shillcdielectronics.com.
sschefer
It's easy enough to prove. Set your tach to read 4 pulses (1/2 of the 8 charging coils) and check it against a decent timing light with a built in tach. I know what happens when I do it.:) Mines set to 6.
Faztbullet
It's easy enough to prove. Set your tach to read 4 pulses (1/2 of the 8 charging coils) and check it against a decent timing light with a built in tach. I know what happens when I do it. Mines set to 6.
The only thing I see it tells you is your tach is set wrong:D This is just reading the AC signal from the stator and coil count has nothing to due with pulses. "RPM signal is related to pulses recieved from the stator and typically all 2 wire stators produce 6 pulses per revolution where a 3 wire system produces 5 pulses."
Above answer is straight out of CDI/Amtech service school handbook...
sschefer
Those of you reading the last couple of posts between FB and me will not understand because I have corrected the original post. FB was right and when I reread it I realized the I must hava had something else on my mind and put up bad info. The original post concerning the stator has been corrected.
sschefer
Frank is almost done.....
Here's the work that was done today.. I didn't stop and take pictures as I was going along.. I would have been stopping every 5 minutes to take pics and all of the information you need from this point on is in the book anyway.
Here are a bunch of shots that you can use for reference..
Just some minor things to do. I have to fabricate a cam and linkage for the carbs and I have to pull the lower unit and align the shift linkage. After that's done I do the link/synch.
Tomorrow is shop cleanup day... gotta do that once in a while..
sschefer
Hooked up the battery to the motor and checked for smoke. We're cool.. Fired off the trim/tilt.. and we're good there also. Worked out the problem with the linkage I just need to bend a new rod and we'll be good to go on the throttle.
I setup the timing pointer and so this is a good time to go through that process...
I use the Jay Smith Racing Engines dial gauge. It has 0-2" range that doesn't require the use of an extension. It also has a fitting adapted to it the screws into the head. I calibrated it with my 6" outside micrometer and it was dead on the money.
The first thing you do is remove all the spark plugs. This will keep compression in other cylinders from causing the cylinder your checking to move by itself.
Now insert the gauge into the plug hold and tighten it just enough to keep it in place. You don't need to crank down on this, remember it is an delicate instrument.
Now rotate the engine on full clockwise rotation and stop when the gauge peaks and starts to fall. Now go counter clockwise and then clockwise back to the peak you noted before. Set the dial face so the 0 on the face is aligned with the pointer.
Here's where a lot of people get confused. You need to turn the engine counter clockwise and count the needle passing 0 4 times. This will be .400 then you need to go and additonal .062 inches and some gauges don't have both rise and fall numbering. If your gauge only has rise numbering then you want to stop at .038 other wise stop at .062 on the fall numbers. Since you are rotating the engine backwards, you reall want to stop somewhere around .030 and then come back on the rise to .038. This will be .462 which just happens to be 45 degrees of timing and coincidently is dwell for the more. Think of dwell as the point in piston travel where all the "stars are in alignment". Kind of a rough explanation but that's pretty much what's going on and exactly why it's used as a checkpoint.
Now lets go check our timing pointer..
Perfect, I didn't have to move this one at all. If it was off, you would loosen the two screws that hold the pointer in place and then move it so that it is aligned perfectly with the .462 mark on your flywheel..
O.K. that's good so now lets check the pointer at 25 degrees. Well rotate the engine clockwise until we reach zero then counter clockwise to .180 on the fall numbers then back clockwise to .150.
Now go check your timing marks on your flywheel. It the pointer is not on 25 degrees then make a mark where the pointer is because where the pointer is now is exactly 25 degrees advanced and that's the number you never want to exceed with your WOT timing. Mine was dead on the money but I knew it would be because I alread indexed the engine with the degree wheel.
This motor is tight and dead on the money but then it's essentially a blue printed motor and we would expect nothing less. Your stock motors might not be as close to perfect as this one but that doesn't mean it won't serve you well as a basic recreational (aka fishing) motor.
I dropped the lower unit and reset the shift lever. Here's a easy trick I'll pass on to you for doing that. Put the engine in neutral. Remove all the nut's and bolts except the front nut then loosen it just until the shifter linkage becomes free from the L/U. Now rotate it until the pointer on the shift rail is pointing to the"N" then slowly tighten the front nut and wiggle the shift rod so the splines line up. Once they line up, tighten the front nut and then put the rest of them back on and you're good to go.
I'll make and new throttle linkage rod tomorrow and then it'll be time to do a pre-start compression test and ball park the intial timing.
sschefer
Went to HD and got a 3' piece of 3/16 rod and made up the new 1" longer linkage for the throttle. The problem is the 1" spacer. I also found a carb linkage piece that would work and a cam. Nice to have a lot of junk boxes!
The only thing left to do now is put a thermostat in, (West Marine only had one so I had them order me three more), and plumb the tell tale and pressure gauge.
I put the remote starter and the spark gap tester on it and gave it a spin but the battery was low (hasn't been charged for a year) so I put it on the charger. You don't want to start this process at a disadvantage and cranking speed is critical in determining a good spark from a weak one. I also have another starter that I had rewound for 24 volts, (my neighbor owns a rewind shop). I may acutally run the 24v starter but we'll wait and see how the 12v works out.
Just for info, you can run a 12v starter on 24v but it won't last as long.
