the oil to fuel ratio for Envirude 25 HP E25REIE
fabienjossic
Hello Everyone,
I just bought an old motor, and the guy couldn't tell me what was the ratio oil/fuel for his motor.
Would you help me or just tell me to what door i should knock?
thank you very much.
fabien jossic
50 parts gasoline for 1 part oil.-----Seller likely is flipping the motor if he does not know ratio.----Or if he has been running it then did he do damage ?
fabienjossic
he told me that he was going to the gaz station, they were doing it for him. So he didn't know.
I hope it isn't damage... i haven't see it running, thanks for your help.
Where did you find this information please?
I think most boating people know that these motors run at 50:1.-----And that has been so since about 1964 model years.-----Not secret information.
Sea Rider
Check cylinder compresion with a dial compression tester to be sure cylinders are in good shape. The 50:1 ratio It's 80 Ml of oil per 3.80 Ltr gallon.
Happy Boating
fabienjossic
Thank you very much guys for your answers, now i am confindent with the 50:1 ratio.
Sea rider, i am not an expert enough to do the test with the dial compression tester. but thanks for the advice.
have a nice day guys.
jhande
Doing a compression test isn't any harder than replacing the spark plugs.
Get yourself a compression tester:
Remove all spark plugs. Screw the testers adapter into the spark plug hole. Crank the motor over about 4 times. The gauge will stop rising at a certain point by itself no matter how much you crank it over.
Write that number down. Repeat for all the cylinders. Compare the numbers or post the results here. ;)
fabienjossic
Hello!
thank you, i didn't it was that easy, I'll try my motor this spring, if it doesn't work i'll buy this cheap device to test it to test my motor.
I didn't know it would be that easy to test.
Thanks for the advice Jhande, have a nice evening.
