Thermastat 3.0
jtracc
Hey guys I would like to replace my thermastat because I think it's acting up. Do I use the 140deg one for a 2000 mercruiser alpha 1 3.0?
jtracc
Re: Thermastat 3.0
The issue I have is the Gasket that came with it has three holes for bolts and the housing from what I can see is two bolts
ktbarrentine
Re: Thermastat 3.0
Where'd you get it from? did you use the right part number for your motor?
oldjeep
Re: Thermastat 3.0
I think it's the water pump. It's,runs at 160 at idle sped when increase to wot and trim up I can only go 1/3 of the way because the the tems rise to 180-190. Can someone tell If have the right water pump kit. 2000 3.0 alpha 1
http://www.iboats.com/mall/partfind...&gd_poid=355205&gd_row=3&session_id=690738319
HAving a 140 degree thermostat only means that it opens at 140. It does nothing to prevent overheating.
And no, that is not the right kit - that is for 1991 and older
What you need is this:
http://bpi.ebasicpower.com/pc/BPI12080/MER5J
(sorry for the non iboats links, but iboats part search is horrible)
series60
Re: Thermastat 3.0
Change the impeller first. If that doesn't fix the temp problem then remove manifold/riser to see if they are plugged with rust. Is this a saltwater boat? [Boynton Beach, FL]
jtracc
Re: Thermastat 3.0
It's been used in fresh it's whole life buT I will be using it in Salt yes. Boat gets trailered so it doesnt sit in the water
jtracc
Re: Thermastat 3.0
Could be, I use quicksilver/Merc kits
If you want to find all the correct merc part numbers for your boat, then go here, launch the parts catalog and enter your serial number.
http://www.mercurymarine.com/parts-and-accessories/parts-catalog/
I am going to pop into my local westmarine and grab a quicksilver kit. The job seems pretty rough. Putting the gear case back seems like a *****. What I have seen you need to put the drive in forward then align the gear case and shift rod? So confused. I am sure I will break something. I always do
oldjeep
Re: Thermastat 3.0
It is easy to do. Put the shifter in forward before you do anything else.
Couple things to remeber:
Don't forget to remove the trim tab - the last bolt for the lower unit is under it.
Don't forget to disconnect the speedo hose - on yours it might be a zip tie or it might be a quick connect
If you can't hold the drive with one hand, it helps to have a helper when you put it back on.
ktbarrentine
Re: Thermastat 3.0
Review the info in this link.... you can also go to youtube and put in "mercruiser impeller" for videos.
http://forums.iboats.com/showthread.php?t=387864
Its easier than it looks... just ask lots of questions when you get stumped (or even before)
jtracc
Re: Thermastat 3.0
The speedo is a little hole in front side the gear case. Do I put it in forward before I even start to pull off the the gear case?
oldjeep
Re: Thermastat 3.0
The speedo pitot is the hole, but when you have the drive tipped up you will see the rubber hose that connects to the lower unit - that is how the water gets to the speedo. Yes - put it in forward before you do anything else.
