Re: Thermostat Removal on a 110 Evinrude, 88'
This is one of those situations where you really want to get a hold of the engineer and Ring his Neck!.<br /><br />The easiest way is to pull the power head.<br />But if you dont want to do that, use a ¼ drive ratchet, with a 10 extension, and 10 mm swivel socket. (atleast I think it's 10 mm)<br />Note that the swivel socket MUST be the kind that is a one piece swivel, not a swivel adapter. The reason for this is that you have no room to work down there as it is, and the extra length of a swivel adapter just doesnt cut it.<br /><br />You will also need an extra pair of hands, preferably small, to hold the assembly in place while the other person tries to start the center screw.<br /><br />I also recommend a light coating of Bellows adhesive to hold the gaskets and corks into place.<br /><br />This job is definitely not for the No Patience kind of person.<br /><br />PS. It is O.K. to swear after your third attempt at re assembly, as listed on page 138 of the manual.<br />Or at least it should have been!
