throttle controls
ringo111
hi guys need help.i hooked up omc controls to 40 hp johnson ,my tilt trim works ,when i turn key on there is a beep,but when i turn key to start no power.to starting motor .if i cross out starter it ingages. battery is good. cables are new. hope you can help.
DargelJohn
Re: throttle controls
What year are the motor and controls? If they are compatible and the original quick connects are in tact, then it should be "plug n play".
ringo111
Motor 1996 . Omc controls everything is comparable ,motor is oil injected
