Re: through-hull fitting and a sea strainer
I'm questing if I should use the belt driven pump with NEW thru hull seacock setup and run existing drive output back overboard. NOW would be the time to do the thru hull thing before I finish bilge painting and installing engine. Many have told me including san juan that stock alpha water pump would handle cooling OK. But many others have said to use the belt driven pump as it is better and easier to work on if needed. and I have it.
From all the past reading I have seen on this subject there are lots of mixed suggestions of what works well and what don't including the known average water temperature of the body of water the boat is usually ran in while using a particular stern drive model vs another stern drive model.
Since it seems like you plan to run both a sea strainer and a closed cooling system then for your best overall results, you would be much better off installing the thru-hull fitting in order to guarantee you are getting adequate water supply vs trusting the small vane sea water pump impeller found in the older alpha stern drives that is questionable for what your trying to accomplish.
Also bear in mind that there is a chance that if you use the alpha impeller along with the new inboard engine thermostat housing, you may experience an overheated condition due to on some engine models, the thermostat housing is designed differently to work with a particular engine model that can be affected by impeller design/water flow rate. There is also closed cooling thermostat housings that could be affected by inadequate water flow both in and out but mainly it's water flow out.
Just be aware that there are different thermostat housings for the Alpha/Bravo/inboard/closed cooling/non closed cooling, and the list could go on and on with different engine models/manufacturers.
I believe you may have been looking for page 16 earlier,
http://www.boatfix.com/merc/Install/gas/86017211.pdf
Do you trailer this boat or leave it in a slip most of the time? If in a slip, be sure to set it up for easy fresh water flush.
