Thru-Hull
MrPhotographer06
when i put my livewell back in my boat whats the best thing to put in it for a drain?
i've got a thru-transom connector in it. I was planning on silioning around it but if theres a way to get a brass thing back in it it'd be great
BigJ08
Re: Thru-Hull
Go to your local boat supply store, they should sell replacement drain tubes in a variety of lengths. Buy an adequate length (you'll probably have to trim it) and install using 3M 5200. Let cure and your good. :D
Bob_VT
Re: Thru-Hull
Be advised that 3m5200 is PERMANENT! Oh it will not leak and whatever part it is will require DESTRUCTION to be removed ;)
3m4200 is the kinder younger brother of 5200 and does permit removal.
Do not use silicone alone because that works best in a fish tank and will normally NEVER last in a boat and will FAIL and leak.
MrPhotographer06
Re: Thru-Hull
haha sorry guys i didnt know i had any replies!
yeah i will be taking the livewell unit back out sooner or later so i better not use that 4200...
i dont really have a boating supply store, but i do have a place that sells boats so maybe they'd have it..
and then theres walmart.. and BPS 2hrs away.. and dicks 30 mins away
65Mech
Re: Thru-Hull
walmart usually has a few tubes lying around. ive been in a couple lately and most of the boat stuff is on clearance
