Re: ticking nosie
i do not know just how long since i had just bought the boat and found the bent push rods, oil pressure is fine holding a study 40 lbs, some one had rebuilt the motor before i got it and i dont know who that was. the reason i got the boat cheap was the guy thought it had a rod knock which it didnt, i dont know what he replaced and i have to assume that the lifters where the original to the engine, i have had lifters go bad before for no apperant reason, if you look back you will see that i replaced the upper drive train inculding the valves is how is was fixed, mine has points, and yes i did check for rub marks inside it.
