tiller to controls conversion
gins331
Can I convert 14ft row boat that I have been using tiller outboards on for years to controls with steering wheel? I know this is small boat but Im getting older and steering could be alot easyer on my back, can I use parts from doner boat? or just buy different boat?
tashasdaddy
Re: tiller to controls conversion
type boat you have, what motor. i did a 14 foot open fishing boat with remote controls, and ezyglide stick steering.
gins331
That setup is pretty freaking cool,I have 69 14ft sea nymph deep v aluminum,I have two motors have not made up my mind yet, 6hp evinrude she runs about 10 mph with that and 56 15hp evinrude almost have her done just need to mount fuel pump want to convert from presure tank it should run good with that motor, that stick steering can that be found in boat bone yards or just look around, that would save me from mounting consoul,
mickjetblue
I would like to know how the speed and shifting control is done with the one stick only for steering showing in a picture.
I would to add a stick control system to my jon boat with steering, shifting,
and acceleration in the stick(s) package. Any tips on a stick package?
Oh, looking again, it seems that the steering stick is on the left, and the speed and shifting
sticks are on the right. Still trying to get it right, and wondering if both hands need to be
on the levers while underway most of the time. Width and reach another concern.
tashasdaddy
the stick steering mounts on the port side of the boat, engine control on the starboard side. it is a great system. this is the 3rd boat i installed this system on. i my pictures is a 55 15hp rude.
steering here, copy and paste without the " "
"http://www.shootnhunt.com/catalog/JM/boat_controls_and_steering/ezy_glide/index.html"
here are the brackets to mount the steering and controls
http://www.iboats.com/Throttle_Cont...d.217131--list_time.1201969823--view_id.40123
dmp_92
I am trying to do the same thing myself. I have the steering system. It just arrived. I have a 1985 4hp evinrude delux motor. What controls do I need. Do I need something that goes from the end of the steering to the motor like you have in the picture? If so what is it called. What type of cables are required for the throttle and gear shift?
mickjetblue
Good luck, DMP! I posted a similar question about 7 months ago, and sent
out a few emails to vendors asking the same, and did not receive a single
response. Tashasdaddy is very generous to share pictures of his own
designed controls, and they are very helpful for ideas.
To your question, in the picture of his motor he attached a custom made
bracket to the motor carry mount, and that is where he attached the swivel
control mount for the steering control. I suppose a piece of angle iron would work the same,
after it is securely attached to the carry mount and drilled with a mounting hole.
I did talk to a motor mechanic once about conversion, and the gist of the
conversion of controls is that there is some liability involved for do-it-yourself
types of conversions. If something goes wrong with the shifting and throttle
controls while you are boating, you are in trouble big time! Nobody has written
a do it yourself guide to convert boat motor controls, and that's probably why. The reality of the situation is that motor mechanics do have a significant
amount of knowledge, and hopefully experience, to ensure a quality and
functional conversion, if they do it. It's much more complex than changing a
spark plug.
I gave up on the conversion, for now, anyway. Most throttle and shifting
controls are brand specific, and that means you need controls to match your
motor. Maybe they can be found in "boat bone yards", or from a marine dealer.
Knowledge transfer does not always come easy. Again, good luck!
tashasdaddy
dmp_92, i have no idea if the 85 4hp is set up to take remote throttle and shift.
