Tilt and trim question
1981
90 hp rude tilt and trim . where do you put fluid in and what fluid. (leaking around cyl. shaft) can packing be tightened or is a seal replacement required? thanks
boobie
Re: Tilt and trim question
Look at the stbd side of the unit and you'll see a resevoir with a plug in it. You can use OMC t/t fluid or Dextron II ATF. No packing, have to replace seals. Fill in the full tilted up position.
Thanks boobi, good info. Does front seels come as a compleat top or just seels? thanks
boobie
Go to shop.evinrude.com and look up your mtr. They have good parts breakdowns.
