I'm not sure this is the right area for this but i'm hoping for some help. I am working on a Nitro for a friend of mine and i'm stumped. It has a 2004 200 hp Mercury outboard salt water edition serial # OT816596 and the trim/tilt has quit working. The system works fine both up and down when wired direct to the pump. My problem is this outboard has 3 solenoids (and i'm not counting the starter solenoid) the 3 solenoids are of the 5 pin relay type and are located just inside the lower cowl on the starboard side. I have tried new relays to no avail, and I haven't been able to find a schematic that shows the third solenoid only schematics i've found all show 2 solenoids "up" and "down". Is anyone familiar with this setup? What is the function of the third solenoid? Any and all suggestions would be appreciated. The pump is the 2 wire type needing to switch polarity + and - to the pump leads for up or down. TIA
