tilt/trim motor 89' 140
huddled
How int he world do you get to the back screws for the tilt and trim motor? Does the whole assembly come off?
Dhadley
Re: tilt/trim motor 89' 140
If the stern brackets are slotted so the unit will slide out then it'll come out with the motor on the boat. If not, then you'll have to suspend the motor (or lay it down) and take off one stern bracket to get the unit out.
huddled
The whole assembly feels loose after taking the bolts out of the bracket, but it wont come out. I did not however remove the pin on the ram up to the motor??
mckee1787
Remove the tlt pin and take the whole tilt/trim out it will make easier to replace the motor and less messy.
