Tilt / trim pump
Been waiting for the season to calm down so that I can repair my tilt/trim pump.<br /><br />Have follwed all the advice (unit slowly leaks down - much like everyone elses).<br />I have an 1989 85 Hp and ordered the correct carb grommets (820719) to fit and reseal the pump valve bits.<br /><br />So $80 later ($63 postage!!, UPS) I'm ready to go but I can't dislodge the two Allen keyed plugs, they are seemingly self welded in.<br /><br />(If the worst comes to the worst and I have to drill them out how far can I safely drill and whats behind them.<br />The cut-away in the Cylmer manual makes them look like they are screw in lid tops-ish and not too technical.)<br /><br />Any advice?
chuckz
Re: Tilt / trim pump
I would not drill them out, they are more than just plugs. If you can't get them out with an allen wrench try grabbing the OD with a pair of plier, you'll have more leverage.<br /><br />If your tilt slowly leaks down I would be replacing seals in the tilt cylinder before I did anything on the pump.
Cheers chuck.<br />Given the unit to a friend with a big vice and all the tools and instuctions to try hard but not go overboard.<br />Thanks
clanton
You paid 80.00 for the 820719 seals?? Try a hammer inpact driver. Heat with hair dryer or heat gun.
Have tryed the leak down test in the Clymer manual to see if it is the valve body or the seals or one-way valves in the cylinder?
