tilt trim wires / conversion from 110 evinrude to 140 johnson
Plumbroke
replacing a blown 110 Evinrude with a 140 Johnson. Engine wires match up but tilt trim are different. Controls on boat have 5 wires 1) blue with white stripe 2) red with white stripe 3)green with white stripe 4) white with brown stripe 5) black with brown stripe, the new tilt has 5 wires coming out 1) blue 2) green 3) black and two others on what appears to be black extension cord wires. Can anyone tell me which go together?
Thanks
Honorary Supreme Mariner
Re: tilt trim wires / conversion from 110 evinrude to 140 johnson
How many wires on the cable going to the trim motor for the 140 ?
Plumbroke
5 blue, green, black and two other blacks
How many wires go into the motor itself ?----Is it a green, , blue and a black ?----Do you have a box with one solenoid for the 140 hp. Or a box with 2 small square relays ?----Any pictures ?
Faztbullet
This is what you should have....
Plumbroke
3 wires blue green black, I assume the other two are for tilt indicator on dash.
V153
Should be blue'n green coming from the trim motor. (Sky blue grass green.) Yes the 2 black, household extention cord looking wires are from the trim sending unit.
