tilt trim wires / conversion from 110 evinrude to 140 johnson
Plumbroke
replacing a blown 110 Evinrude with a 140 Johnson. Engine wires match up but tilt trim are different. Controls on boat have 5 wires 1) blue with white stripe 2) red with white stripe 3)green with white stripe 4) white with brown stripe 5) black with brown stripe, the new tilt has 5 wires coming out 1) blue 2) green 3) black and two others on what appears to be black extension cord wires. Can anyone tell me which go together?
Thanks
Re: tilt trim wires / conversion from 110 evinrude to 140 johnson
How many wires on the cable going to the trim motor for the 140 ?
Plumbroke
5 blue, green, black and two other blacks
How many wires go into the motor itself ?----Is it a green, , blue and a black ?----Do you have a box with one solenoid for the 140 hp. Or a box with 2 small square relays ?----Any pictures ?
Faztbullet
This is what you should have....
Plumbroke
3 wires blue green black, I assume the other two are for tilt indicator on dash.
V153
Should be blue'n green coming from the trim motor. (Sky blue grass green.) Yes the 2 black, household extention cord looking wires are from the trim sending unit.
