Timing and Sync of Merc Inlines (to 1988)
tengals123
Master Chief Petty Officer
Re: Timing and Sync of Merc Inlines (to 1988)
clams thanks for this great post. I have never held a timing gun before, littlelone timed an outboard. After going out to the garage and having a look at your description and my motor, im sure tomorrows timing session will go well. A quick question though. <br />you say primary throttle p/up at 3-4BTDC and max advance at 34BTDC.<br />My clymer manual states 5-7deg primary BTDC<br />and 36.5deg max spark advance.<br /><br />Which one to follow?<br /><br />cheers
Clams Canino
You can go with 5-7 , 3-4 is just a generic that will work on *all* of them, no biggie there.<br /><br />34-35 max advance is safer on todays gas. Same reason the "direct charge" models are 21 instead of 23-27. <br /><br />-W
tengals123
Thanks, I shall go with 5-6deg, primary and 35deg max advance.<br /><br />Thanks again. I'll post my results.<br /><br /><br />cheers
tengals123
Well, as stated i'd post my results. FANTASTIC. <br />It has never run better.<br />As stated though, i can only get the idle in gear at about 700rpm. 800-850 in neutral. I'm happy with that though, she sure sounds smooth.<br />Cheers
Clams Canino
That's not bad..... old reeds and reed blocks affect the idle. Yours is in normal range.<br /><br />-W
Mercury140-I6
Clams:<br /><br />What do Reeds/Reed blocks cost for a 79 140?? Or should I leave that kind of work to the pro's like you and just get a complete powerhead? and if so, do you have or can you get a 140 or should I just send you the one I have? I worked on a 4.5 and a 7.5 in highschool, but these monsters really intimidate the hell out of me.<br /><br />Craig
Clams Canino
Craig, I'm not even sure that new reed blocks are available, I just hoard all the good ones I find on bad cranks - to use later to replace others.<br /><br />Reed=work on the thing pretty much requires removal of the crankshaft. Shoot me an email to discuss further if you wish.<br /><br />-W
roger3645
CC: I have a 75 mercury 850, I have the max advance set at 27 degree. After reading your post<br />I wonder if I should set it to 21 degrees. What will this do for the motor?
timmathis
Roger, :) If it is a pre 1988 inline Mercury. I'm not Clams, But I can tell you this.. You better set it at 21 degrees max or for the older crossflow 34 degrees max :eek: <br />Tim
crem1
Hi Tim!<br /><br />Thanks for the information I really appreciate it.<br />When I did the compression test the engine was warmed up<br /><br />Again Thanks<br /><br />Alex
MercFan
^<br />Looked my *** off for this.<br />Search for Clams didn't work, ditto for Sync
Clams Canino
I've been (quietly) trying to get JB to add this post to the Official Annointed FAQ. I think I need to sacrifice a rubber chicken while facing East or something. :D <br /><br />-W
timmathis
I second that motion to add this to the FAQ, Tim
crem1
I don't know the consequences of Clams Canino's request but if you have to stretch a rubber chicken's neck to get results then by all means.<br />I'll third the motion<br /><br />Alex
pinkfloyd
This should be in FAQ. Great hard to find Information!!! Floyd
crem1
Pinkfloyd is right, hopefully management will see fit to have this topic go where no other topic has dared to go before. I'm confused!!!!!<br /><br />Alex
