Hi all, I have a 98' 70hp Suzuki. A few weeks ago it started to make a bunch of clattering noise. I brought it in to the dealer to have him adjust the valves (thought that was the problem), which he did. They were all a little loose by the way. The clatter did not go away however, it seems to be coming from some thing to do with the timing belt. If I take the fly wheel and turn it a little bit the timing belt pulley attached to the crank stays still for about 8 or 10 degrees before it moves. The dealer is pulling off the fly wheel tommorow and check it out. Any one had any similiar problems? Any prolems with the tensioner?
