timing light connection
tfasbind
I have a '85 OMC I/O with a 5.7 litre V-8.
I want to check my timing and according to the manual it says to connect a timing light to an adapter for number 1 spark plug.
Does anyone know where I can get this adapter?
I have an induction type timing light and tried clamping it on to the #1 plug wire with the power leads connected to the battery but got no light. Is this because the wires are different than regular automotive plug wires?
Boomyal
Re: timing light connection
No, the wires make no difference. If your lite has the induction clip and you have a good connection on the battery, that is all that is necessary.
Is there a dial on the back? Have you zeroed it? Did you pull the trigger?
Always a possibility that the lite is bad but I think they are pretty durable.
tfasbind
tfasbind
This is actualy the 2nd timing light that I've tried on this motor. I bought a new light (induction type) from Amazon.com. Tried it. Nothing. I figured it was the light and sent it back. Then I bought a used light from a local used tool store. Tried it. Still.no light.
I've used timing lights in the past (probably 30 years ago) and had no problems.
It seems pretty unusual that 2 lights would be defective.
I've tried clipping it on to other plug wires (in case there was a problem with #1 and got the same results.
The Engine Is running,.. right,..??...
Try the Coil Wire,.......
I Suppose you Could have 2 Strikes...............
tfasbind
tfasbind
Engine was running and at proper RPM. I pulled the trigger on the light, no dial on the back (simple induction type gun).
Don S
Try it on your truck or car and see if it lights up. May be the type wires you have on your engine. Does your timing light have a positive and negative clip for the battery also? If so they BOTH must make good connection to work.
And Forget about that "Reply + Quote" Button,.....
Just use the Dialog Box at the bottom of the page......
