Re: Toon turbulence
I agree, the water is turbulent from the nose cones back so there isn't any "good" water under the boat.
Your size description is a little confusing to, it is 16' long and 6' wide?
To get it to set level you woudl have to have the engine almost in the center of the boat, it woud be better to leave the engine in the back and shift weight forward to balance.
I did not leave enough space between the numbers
The deck is 8' wide
Center of toon to center of toon is 6' wide
Pontoon length - short 19' 3"
Pontoon dia. 25"
Motors- I have a choice of a CW or a CCW 25" leg 150 Mercury's (government auction)
There is no motor pod as I have not designed or built it as of yet, this is a home built and designed pontoon boat.
I have got a idea for the pod but still need to figure out how to make it more adjustable for obvious reasons.
There are no plans, directions or even a suggested rating's as again this is a home built and designed project.
This project did start out with reasonable expectations and limits, it has just morphed to the point where I have to see it thru.
