Re: Towing With Explorer
thats right.. the 3.07 the highest gear ford was useing then,its like taking off in 2 gear if it was a stick,but at 75 mph Im doing 2100 rpm's.. this is why it overheated.. Im going to ethier replace the motor & trans or change the gear to a 3.73 and add a parallel flow cooler in series with the internal and external I already have.. Thanks for your reply.. I don't want to get rid of the truck,I like it,have it set up the way I want ,just need to deal with the pulling issue...
I agree,its not just that I have a the worst trans ford has ever produced, A junk A4LD,its that explorer in 1991 have 4 gear ratio's that they used,the 4.10 , 3.73 - 3.27 , and 3.07, and guess which one I have???I've owned several early Explorers and Rangers, the A4LD is not the more robust trans made, but with proper driver habits, proper service, and a good cooler it can be made to last. I would say however that about 5500lbs would be the max I'd attempt to tow with that vehicle, at least on a regular basis.
Ford did only make that trans for a few years, but the newer versions are still the same basic trans. Many internals are near identical and many interchange with the older unit. The overdrive automatics that were used in the full sized truck were a lot better for towing. Keep in mind that the A4LD is a light duty trans, it obviously wasn't designed with towing in mind.
