I am talking about the two red tail lights on the trailer.
I did not notice if the tail lights on the truck also dimmed.
I did not noticed if the side marker lights on the trailer dimmed, But I will say that if they did it was not as noticable as the dimming on the rear trailer tail lights...
Can't really put it plainer than that !!!!
Unless I put it this way ......
Bad ground, Bad ground, Bad ground, Bad ground etc![]()
A dead short will blow a fuse, not cause the dimming the OP is experiencing. This is almost definitely a ground problem.Not true. Not even close.
A short to ground is common for old wires and it can be located in the plug or anywhere back to the light. I pinched a couple wires with a new bolt and shorted out most of the lights.
A short to power will send current to the wrong location or give you bleed over. Bad contacts at the bulb also create resistance
Resistance created by corrosion or hot wires will create low voltage situations that will create the dim bulb effect.
This is when I noticed that the truck tail lights also dim ( running lights on, turn signal on, opposite side of flashing turn signal dims with flash ) However, the condition is not as noticable on the truck as it is on the trailer.
So now what ?
Ok, I got some time to do some work on this today.
First, I just went ahead and and ran ground wires to the side marker lights and tapped them into the white ground wire for the trailer harness, so now all four lights are tapped into this wire witch is also bolted to the frame of the trailer itself.
But the condition did not change, This is when I noticed that the truck tail lights also dim ( running lights on, turn signal on, opposite side of flashing turn signal dims with flash ) However, the condition is not as noticable on the truck as it is on the trailer.
I unplugged the trailer, but the truck lights still slightly dimmed.
I switched the flashers ( turn / emergency ) but this had no effect.
I gave it a higher idle, but this also had no effect.
So now what ?
Hi Guys,
I am just wondering why one side of my running lights dim down, when the opposite side has the turn signal on ?
It does it when either the left or right turn signal is on .![]()
We did - the prob is in the tow vehicle, not the trailer. It's a lot easier to make sure all the ground connections are right before moving to voltage leaks. My dvm leads aren't long enough to reach to his truck or this would be fixed.
Changed you mind yet ????
Lets run through this again. If the lights dim, when you turn on other lights, its because they are using up some of the current going to those bulbs.
When you have more than one bulb in line between the positive and the ground, the voltage and current is divided between both of the bulbs. They will be dimmer than one single bulb. In every circuit, the voltage is used up. Its either used up by lights, shorts or resistance (thats what resistors do) as well as rheostats and other mechanisms that reduce current. A poor connection will create resistance.
If you had a bad ground, you would always have dim lights, not just when you turn on the blinkers. If you want prove you have adequate grounding, run a jumper cable from your boat trailer to your vehicle.
I dont know how long you had the trailer, but its possible that the turn signals and the marker lights have some kind of connection. A frayed wire or split end might allow a single strand of wire to contact a separate surfaces. If anyone worked on the trailer, but not even the lights, it could become a problem.
When in doubt, go back to the basics. Check each circuit on the truck plug. Check for frayed wires on both sides and in the junction box if one exists.
And check the braided ground from the engine to the frame. Let us know how you make out.
This is a description of bulbs wired in series, which is NOT the case here.They are in parallel. A long as the circuit is able to provide adequate amperage (current), the bulbs will remain at the same brightness level.When you have more than one bulb in line between the positive and the ground, the voltage and current is divided between both of the bulbs.
