wellcraft19
- Joined
- Jun 21, 2011
- 201
Re: Trailer lights.
When working trailer light problems, I do the following:
1. Clean out the trailer light connector (especially if it is the smaller 4 wire connector) from crud and corrosion
2. Reset all the bulbs and verify that they work individually when placed in their sockets
3. Use a power source (battery, portable 12V supply, or other) and power up each circuit in the trailer individually
4. If not working, fix ground connectivity issues
5. Reconnect and try on vehicle (or several if the trailer is "OK" but the trailer/vehicle combo is not).
Since most modern vehicles (but probably not a 1977 Dodge...) have what is called a "trailer light converter" (due to the fact that the car likely have separate turn signals and the trailer uses the brake lights for turn signals, I've seen those "converters" fail as well. Short circuit or just plain overload due to too many lights on the trailer.
What I did (Toyota LandCruiser) was to pull a dedicated power source wire from (fused) battery directly to trailer connector in order not to overload "trailer light converter". This runs via a relay that is trigged by the 12V "tail light" feed coming out of the "trailer light converter". In case you get a short in the "tail light" circuit, not the "brake light" circuit), you are less likely to damage the vehicle's tail light wiring (+it provides me with a relatively hefty source to feed other stuff in the back of the car, all based of course on the size of the wiring installed).
