EJ42955
Thread starter- Joined
- Nov 9, 2010
- 47
After reading a lot of threads and info, I'm wondering if the boat/trailer combo I was given is set up correctly.
1. (Not picture) I'm pretty sure the rear rollers are wrong. They are about 2 inches forward of the transom.
2. Does the winch look acceptable you? I've read it should be adjusted so the winch strap is parallel to the trailer.
3. Should the rollers be farther to the outside of the hull?
If you were going to readjust the trailer to fit the boat, where would you start? And, then change what next?
Thanks,
EJ
Thanks,
EJ
