beason
Thread starter- Joined
- Mar 15, 2011
- 338
ok so here is the deal.
I trailer, so i remove the plug after each use and leave it out until the next outing. i currently use a cheapo crescent wrench to do the plug.
My trailer has a flip up roller system, and the last roller is out past the plug a bit, causing issues when using a large "prop wrench" to tighten it. The Chaps run an "extended V plane hull" which has the lower and plug in a small pocket built into the transom
similar to this
when not in use, my plug and wrench stay in the small locker built into the swim platform. this is normally damp to standing water at least for a few days after use. This has caused the wrench to rust up, and stains to form in the locker.
What im looking for is a wrench, that wont rust, but that is small enough to work in this confined area. A mini version of a prop wrench that is just big enough for the transom plug would be great, but i cannot find one.
This is the closest i have found, but i have never used one so i dont know how well it works
anyone have experience with this product? or can suggest something else?
similar to this
