Here we go. This is just a shot of my transom. Based on what i can see from the inside, there is no wood behind the "extended flares" on the top sides. So, either the wood is just in the center piece under the engine, or extended on the sides. However, because of the different angle between the center and the sides, i am guessing not, or atleast separate pieces.
The idea is too cut the top of the splashwell, and possible insert new pre-cut plywood. If not, i am planning to use a liquid "pourable" transom.
What do you think? Will inserting a new plywood from the top and possibly filling the cavities with with polyester resin be a possible solution?
