I'm in the middle of my transom and stringers replacement. 3/4 of the deck is complete and in place. I happened to be grinding away at the transom joint and went thru the bottom of the boat a teenie bit. It is not more then 2 inches. My question is should i sand the inside down so its even and go from there or do a inside and outside patch? <br />I'm just wondering the best way possible the boat also has minor chips thru the gel on the outside.<br />Any advice?<br />I will also be putting up all the pictures for members to view once i get a little ahead on this.<br />thanks<br />garrett
