Tri hull trailer
woosterken
Re: Tri hull trailer
Red,
my '74 MFG has a maxium beam of 86"
woosterken
reelfishin
I've had trihulls as narrow as 60" and as wide as 94" but most seem to be in the 70 to 80" range from back then. Most fit between the fenders of the larger width roller trailers, but not all. Back then it seemed that most boats sat high and above the fenders, making trihulls sit much higher. An old bass boat trailer or any wide axle trailer might be the best ticket.
pkrainert
I noticed that the boat is only resting on the roller closest to the transom. Should it be resting on all of them?
reelfishin
You want the boat as evenly supported and as low as possible on a particular trailer if you have rollers that aren't touching the hull, adjust them to contact the hull. Their not doing any good if their standing out in mid air.
mcderyan2005
as long as the clearance is there around the fenders, you may be able to put the trailer on jack stands, remove the axle from under the springs, and reinstall above the springs. this will lower the trailer by a few inches
