123bigfrank123
- Joined
- Jun 18, 2010
- 10
Greetings, I have a 1992 225 hp evinrude which does not trim or tilt up. i have switch the relays up. it goes down just fine.
Greeting RRitt, I was on my boat this morning and I realized I do not have voltage going in to the relay. motor works fine when i hot wired it. Where is the trim limit sensor located at?Check for a shorted trim limit sensor. check wiring into relays to confirm that your "up" control voltage is being delivered. Hot wire trim motor to confirm working motor. It should be one or the other.
