Trim Guage
sandollar1978
Hello, can I install a trim guage to my boat? The motor is 1979 Evinrude 55HP 2 cycle.<br />Where can I find the trim sending unit the trim gauge does not come with sending unit! <br /><br />HAPPY HOLIDAYS TO EVERY ONE!!
OBJ
Re: Trim Guage
Hi Sandollar..<br /><br />The sending unit was built into the Port Cylinder on those TNT units. Look for a terminal on that cylinder if it's a stock TNT unit.<br /><br />The Yellow/Gray lead comes off the recitifier. That would be located on the Starboard side of the engine.<br /><br />Hope we've helped.
sandollar1978
Re: Trim Guage
Thanks OutBoardJim, But what is a stock TNT?<br />Also what does the sender unit look like? The 1979 evinrude 55HP is original outboard so should it have a sending unit and what do I need to connect the trim guage besides the trim gauge? Thanks alot OutBoardJim!!
OBJ
Re: Trim Guage
TNT means Trim N' Tilt. Back then, these were an add on you had to order with the motor. If you look at the engine,and if equipped with TNT, there should be two hydraulic cylinders between the transom brackets with a TNT motor and reservoir mounted to the starboard transom bracket. Look for a stud with a nut and rubber cover on the Port cylinder. The sending unit was built into the cylinder so all you see is a stud and nut.<br /><br />If you find this stud, connect the post on the TNT gauge marked "S" or signal to the post on the cylinder. The "I" or ignition to a 12 volt source and the "G" or ground to a good battery ground.
sandollar1978
Re: Trim Guage
Great thanks my out board has a TNT where you could lift the motor and lock it up so its sits up hi. But you have to do it manuel I hope this is what your talking about I'll try to look for the bolt with a nut. I want to thank you for helping me out! :D
OBJ
Re: Trim Guage
Sandollar...if yer goin ta do this yerself, ya' really need ta' get a service manual. The generics are OK and ya' can get them here from iboats. If you want the real OEM service manual which is the preferred manual, check the link below. Will cost ya' a few bucks more, but may be worth it in the long run.<br /><br /> http://ww3.kencook.com/evinrudejohnsonmanuals/ <br /><br />Good Luck!!
sandollar1978
Re: Trim Guage
Great Thanks. Motor does not have tilt & trim but thanks for helping... :D
