Re: Trim Guage
TNT means Trim N' Tilt. Back then, these were an add on you had to order with the motor. If you look at the engine,and if equipped with TNT, there should be two hydraulic cylinders between the transom brackets with a TNT motor and reservoir mounted to the starboard transom bracket. Look for a stud with a nut and rubber cover on the Port cylinder. The sending unit was built into the cylinder so all you see is a stud and nut.<br /><br />If you find this stud, connect the post on the TNT gauge marked "S" or signal to the post on the cylinder. The "I" or ignition to a 12 volt source and the "G" or ground to a good battery ground.
