Trim motor clicking, not functioning.
lmorefield41
Hey guys, you may remember me from this post. http://forums.iboats.com/showthread.php?t=519268 I haven't been on here in a while as I've been busy restoring this entire boat. I'm about 90% done with the mechanical, then on to the interior. I've run into a problem with the trim motor. I've researched and researched, and tried multiple things, to no avail. My problem with the trim is that when I push up, down, or trailer only, I just hear a clicking sound. It doesn't actually function. It will click one time with each button pressed, then that's it, no matter how long I hold the button. I've checked the connections and everything looks solid, nothing loose. I know this is very broad and general, but if you guys can start shooting ideas or solutions at me, I'd greatly appreciate it.
Thanks in advance.
Fishermark
Re: Trim motor clicking, not functioning.
Either a bad solenoid(s) or connections.
lmorefield41
Hey thanks, I will execute the troubleshooting steps from the diagrams and see what we come up with.
lmorefield41
Ok, so I've completed all of the troubleshooting steps. The electrical components are all in tact and functioning properly. I ended up taking the motor apart to clean and rebuild it and it's damaged beyond repair. With that being said, I need to replace it. I've searched online for the exact motor and the prices are a little high. My question is, can the 88183A12 replace the 88183A11 motor. My motor is the 88183A11. I found multiple 88183A12 motors online, brand new, for less than $70. I haven't found my exact motor for less that $300 online. Thanks in advance guys.
lmorefield41
Another question I have is if these motors are not interchangeable, Will I be able to purchase an entire new motor/reservoir and have it function on the outdrive that I currently have? If so, there are the 88183A12 motor/reservoir combos that are listed for $189.00 brand new. That's still cheaper than the motor I have, by itself.
Westgunn
I'm running into the exact same problem. Very interested in any answer available. Any updates? It's the last piece on my Intimidator puzzle....well except for the windshield replacement.
I'm guessing it's a difference in number of bolts used to attach the motor to the reservoir? Even the salvage yards are pricey compared to the A12 version. :facepalm:
Ayuh,.... Welcome Aboard,.... Start a thread of yer own, 'n We'll see if We can find ya some answers,...
Please include the make, model, 'n vintage,... serial numbers are a plus...
Westgunn
Alright, will do.
