gillmaster
Thread starter- Joined
- Jul 20, 2008
- 8
When I trim my 2002 130 Johnson down, the (trim) motor runs but I have to physically push the motor down. it comes up ok, and once the engine is down and in the running position and I am under way both up and down work fine, but when I put the motor up all the way it does not go down unless assisted. The fluid level appears to be ok, and the tilt motor runs but it will not lower the engine when it is tilted out to the full position it needs to be pushed down with the trim tilt motor running.
Any suggestions?
Any suggestions?
